Solved! Go to Solution.
Can you enter your phone number and post results. Remember delete number only. https://www.btwholesale.com/includes/adsl/adsl.htm
Can you post the stat stat from your router. If hh6 then go to advanced settings then technical log information
If hh6 then the technical log information not the actual technical log. Should show hub info connection time,connection speed, attainable speed, noise margin etc
At present you connection speed is about attainable with noise margin about normal 6db leaving no scope for faster speed
connection time is less than 2 days was that router dropping connection or manual reset?
are you using the test socket with a filter to see if that improves speed by eliminating your internal wiring
try quiet line test. Dial 17070 option 2. Should be quiet and best with corded phone
