ScottSilver
Message 1 of 16
Speed lower than estimated
I had BT Infinity installed 22 days ago and had an estimate of 60-79Mbps and an upload estimate of 19-20Mbps. Since day one I have only ever been able to obtain 54Mbps download and an upload of 7.5Mbps.
I was advised the HH5 causes issues and I should use a modem, so I got an Openreach Modem and I've left that on now for 12 days and still no improvement.
The results from https://www.dslchecker.bt.com are:
FTTC Range A (Clean)79.5602019.6--Available
FTTC Range B (Impacted)70.943.82013.9--Available
WBC ADSL 2+Up to 7.5--6.5 to 8.5Available
WBC ADSL 2+ Annex MUp to 7.5Up to 16.5 to 8.5Available
ADSL MaxUp to 5.5--4.5 to 8Available
WBC Fixed Rate2----Available
Other Offerings
FTTP on Demand33030--Available
Using the BT speed test, my IP Profiles are: 57.42Mbps download and 20Mbps upload but the speeds obtained were 56.4Mbps download and 7.2Mbps upload.
Would anyone suggest there is an issue or is this as fast as it will go? A big miss on the upload estimate, even on impacted.
15 REPLIES 15
Distinguished Guru
Message 2 of 16
Re: Speed lower than estimated
Hard to say without seeing your line stats reported by the modem, including noise margin.
If not, I'll try again 🙂
ScottSilver
Message 3 of 16
I could always pop on the hub 5 quickly to take a look if that would help 🙂
Distinguished Guru
Message 4 of 16
Yes it would. If you can post the line stats reported in Troubleshooting/Helpdesk, lines 1-13 please?
Guru
Message 5 of 16
If changing modems around, always power them off first rather than just disconnecting the phone wires to them.  That reduces the risk of DLM seeing it as a possible fault.  If you've got an appropriate interface into the modem, disconnect the VDSL connection using that interface.
ScottSilver
Message 6 of 16
I noticed that advice from somewhere before so that is what I did, power off first 🙂
Well here they are, what is interesting is that it has synced at a higher 60Mbps (never been this high).
1. Product name: BT Home Hub
2. Serial number: ***HIDDEN***
3. Firmware version: Software version 4.7.5.1.83.8.173.1.6 (Type A) Last updated 03/08/14
4. Board version: BT Hub 5A
5. VDSL uptime: 0 days, 00:01:36
6. Data rate: 7224 / 61590
7. Maximum data rate: 7186 / 61582
8. Noise margin: 5.8 / 6.5
9. Line attenuation: 0.0 / 19.5
10. Signal attenuation: 0.0 / 19.5
11. Data sent/received: 0.0 MB / 0.0 MB
12. Broadband username: bthomehub@btbroadband.com
13. BT Wi-fi: No
Distinguished Guru
Message 7 of 16
Yes, looks like noise is seriously affecting your connection which may well be a dodgy install.
Currently your upload is running as fast as possible without some sort of intervention by an engineer to fix whatever problems there are with your install.
ScottSilver
Message 8 of 16
Quiet line test is crystal, forgot to mention I tested that.
I have spoken to BT on the phone but they said all is fine. Not sure what to do next because as we know, the call centre is pretty much useless when you talk technical to them.
Distinguished Guru
Message 9 of 16
Yeah, you may as well be speaking to a foreign country.
Is there any problem with your installation?
Is the line from a pole or underground?
Is there any boxes or filters before the master?
Do you have extensions? alarms? sky boxes?
Is the modem on a data extension?
Did you have ADSL before, what was that like?
Stuff like that... 😉
ScottSilver
Message 10 of 16
The master socket wasn't fitted correctly but that was fixed.
Pole but the line from the pole serves 6 properties in this block.
There is what seems to be a junction box outside near the roof where 6 lines come out of that.
None
Nope
only infinity at another property.
