Message 1 of 3
Speed problem again.
FAQ
Results Image not loaded
1. Best Effort Test: -provides background information.
 Download Speed
 1.3 Mbps
0 Mbps33.84 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 1.3 Mbps
 For your connection, the acceptable range of speedsis 27.5 Mbps-33.84 Mbps .
 Additional Information:
 IP Profile for your line is - 33.84 Mbps
2. Upstream Test: -provides background information.
 Upload Speed
 0.01 Mbps
0 Mbps10 Mbps
Upload speed achieved during the test was - 0.01Mbps
 Upstream Rate IP profile on your line is - 10 Mbps
This test was not conclusive.
please close the window using 'Exit' button and contact your ISP for further assistance with these results.
Please visit the FAQ if you are unable to understand the test results.
Three or four days a week get speeds like this,after a few hours increase to what now seems to be normal mid 20s way down on the 32 to 35 I use to get. Weekends and evenings tend to be worse times.
2 REPLIES 2
Message 2 of 3
Re: Speed problem again.
this appears different from previous as it was connection speed whereas this is download speed
was test done with a wired connection not wireless?
can you try http://www.speedtest.net/ and post results please  must be done wired and with nothing else on netwrok running
Message 3 of 3
Back up to mid 20s again now, only slow for a couple of hours today, sometimes it's all day.
Result ID
PING ms
149
DOWNLOAD Mbps
25.40
UPLOAD Mbps
6.29
 That's about best I get now. I've tried wired and wireless results are the same. The connection speed hasn't changed for a long while.(ip profile).
