FrazUK
Message 1 of 16
Speed problems
Edit: I forgot to mention i have already power cycled both the modem and hub.
Hi,
I have been with BT on BT Infinity 2 for about 5 months now. When I first ordered, my speed was estimated to be 36/6 (and still is when I check availability on this number). When Infinity was installed, I was getting 26/3 which I wasn't very happy with and was told it would increase over time by BT support. After a few days my speeds dropped to around 21/3 so I contacted support again (this was after the supposed 10 day trial period) and recieved a phone call from the engineer team.  He explained that this cannot be treat as a fault unless my speed drops to 50% or below of my original estimate. Well now it has.
Heres the results from a bt speed test..
And heres the results of a tracert to bbc.co.uk
Ive always had low speeds and problems on this line for some reason. A few houses at either side of me are estimated more in the range of 60mbs. Theres also a green cabinet about 350meters to the right of my house on the same road and another green cabinet on the main road outside of the estate.
Links with routes from my house to the cabinets
Right
Main
I would appreciate it if this could be looked into. Cheers!
15 REPLIES 15
Guru
Message 2 of 16
Re: Speed problems
Those pings actually indicate that you're on fastpath.
How are you connecting wireless or with wired?
Guessing wired looking at the response time to the hub but you know. 😛
If this helped you please click the Star beside my name.
If this answered your question please click "Mark as Accepted Solution" below.
FrazUK
Message 3 of 16
Re: Speed problems
Yes I'm using a wired connection.
What is fastpath and why would I be on it?:o
Guru
Message 4 of 16
Re: Speed problems
Fastpath is a setting that skips detection of packets mainly and various other things increasing response times.
The usual setting is Interleaving which would give responses of around 28 on your first ping and about double the rates of the rest of them. You need a stable line for the DLM to switch you on to FastPath so maybe it's a problem with the ports on the Hub which are very common.
Have you tried a different ethernet cable?
FrazUK
Message 5 of 16
Re: Speed problems
Well i have just ran the speed test on the other pc which is connected via wireless and i get the exact same results.
FrazUK
Message 6 of 16
Re: Speed problems
Also, i have noticed online games seem to be having problems with missing packets. Bullets not landing, latency between clicking and the weapon actually firing and generally unreliable performance all while having a ping around 20-30
Guru
Message 7 of 16
Re: Speed problems
Sounds more like hitboxes/net settings and low FPS.
FrazUK
Message 8 of 16
Re: Speed problems
Nope. These problems occurred at the same time as my speed problems.
Guru
Message 9 of 16
Re: Speed problems
I've only acutally just seen your IP profile, I would advise contacting the moderators.
There is definetly a problem, ali being your cable comes to mind.
They will take personal ownership over your case until it's resolved, you can contact them here. They normally respond within 3 days.
FrazUK
Message 10 of 16
Re: Speed problems
@ryant704 wrote:
There is definetly a proble, ali being your cable comes to mind.
So does this mean an engineer might actually come out and have a looksie? That would be awesome, finally!
Going to contact them now, thanks!
