Guru
Message 11 of 16
Re: Speed problems
Yes, more than definetly. I would expect an engineer to come out, check your equipment and run a line test at the very least.
If this helped you please click the Star beside my name.
If this answered your question please click "Mark as Accepted Solution" below.
EntraVenuS
Message 12 of 16
Re: Speed problems
what kind of an answer is that ?>? !!
FrazUK
Message 13 of 16
Re: Speed problems
Just posting a couple of images as requested from a a member of the mod team. Results of a speed test and tracert today
Guru
Message 14 of 16
Re: Speed problems
I'm assuming he meant for you to ping bbc.co.uk not bb.co.uk
FrazUK
Message 15 of 16
Re: Speed problems
Haha you're right. Didnt notice that typo. Will replace the image now.
FrazUK
Message 16 of 16
Re: Speed problems
Well the BT engineer just left about 10 minutes ago after about 4 hours. I have to say I'm well chuffed Smiley Very Happy
Check it out ... http://www.speedtest.net/result/2440094978.png
