kalato
Message 11 of 15
Re: Speed reduced
True true Webby, Like I said I dont want to complain but I use the speed for downloading videos to edit etc so the speed is pretty important for my work at my job and I get things done faster.
Message 12 of 15
Re: Speed reduced
We'll leave it at that then if you're using it for business purposes 😉
kalato
Message 13 of 15
Re: Speed reduced
Haha nah its not so much a business 🙂
mike63uk
Message 14 of 15
Re: Speed reduced
kalato
Message 15 of 15
Re: Speed reduced
I think you were right webby my connection has gone back to 70+, i think I had problems yesterday as my connection was slow and all the stats were going crazy plus I seen alot of BT vans around my area pulling up the phone holes.
