Message 1 of 9
Speed reduction since damaged fibre cable
Hi,
In early September Thames Water managed to sever the BT fibre cable for our street while doing some ground works. The outage lasted at most 48 hours until it was repaired by BT OpenReach.
Ever since the repair I have noticed that our broadband speeds have dropped from those enjoyed before - see route speed test graphs below. Previously download speed was ~70mbps, now its dropped to ~50 mbps. Given the BT Wholesale Speed website no longer appears to exist I don't know where to check the exchange stats.
Could this drop be caused by the 48 hour outage resulting in a cap being applied because the line management service thinks the line is faulty and reduced it to stabilise it - or could it just be that the repair has impacted the speed of the line?
Thanks,
G
Speed test results leading up to the fibre cable damage  (shown by drop to ~50mbps)Speed tests since the fibre cable was repaired
8 REPLIES 8
Message 2 of 9
Re: Speed reduction since damaged fibre cable
@Haggini
The checker does exist here
Message 3 of 9
can you post your hub stats please  advanced settings then technical log information .  see what attainable speed you have and current noise margin
Message 4 of 9
Was it a Fibre Cable or Metallic Path like Copper or Aluminium?
Pure FTTP shouldn’t be impacted by DLM, only FTTC Services would be.
Message 5 of 9
Thanks all for helpful responses so far.
Great to see wholesale checker does still exist - given I don’t have a landline number what should I use to check this?
In terms of hub - I use my own NETGEAR Orbi router and draytek vigor setup  - I may have some images from a previous post with some of that info. Will be a few days before I can post updated numbers.
re: type of cable - this I don’t know - but I suspect it’s FTTC.
Thanks,
G
Message 6 of 9
Try using  fast.com and see what result you get
Message 7 of 9
Here’s the exchange reading from 1 year ago
(this was from a separate issue when I returned to BT and was put on a fibre 1 profile despite signing up for Fibre 2 - I’ve been moved to EE since then. The mods were able to resolve this for me back then)
Message 8 of 9
Scratch that - here’s the latest up to date exchange information.
Message 9 of 9
@imjolly - Hi im back now - so I can get router stats to go with the exchange info in my previous post. Like I said I don't use my BTHub, I have a Orbi 6 with satellite. Here are the connection stats from it:
PortStatusTxPktsRxPktsCollisionsTx B/sRx B/sUp Time
WAN1000M/Full3350381647296734700918107338 days 04:19:04
LAN11000M/Full14120210595101519059445538 days 04:19:04
LAN2Link Down00000--
LAN3Link Down00000--
2.4 GHz WLAN b/g/n/ax573.5M5258801628770057072028138 days 04:20:51
5 GHz WLAN a/n/ac/ax/be1201M258836992116996174028739638 days 04:20:51
WLAN Backhaul2402M334314707128760103096749538 days 04:20:51
If this isn't what you're after let me know and I can try and find it.
Thanks,
G
