Message 11 of 16
Re: Speeds disappointing after upgrade
as I said your up profile certainly suggests you are on infinity 2
Message 12 of 16
Connect to the test socket and leave it for a few weeks, see if the connectivity improves/banding gets removed. If not, raise a fault to BT.
Newbie
Message 13 of 16
Connection to the mastersocket made.  I shall return IF I have positive results.
Many thanks
Message 14 of 16
Make sure you are connected to the test socket behind the front plate.
Newbie
Message 15 of 16
Quick update:
An engineer is coming out on Tuesday. Apparantly I have a fault, which is preventing me getting the promised speeds.
So, the suggestion of banding could be true.
Thanks J
Message 16 of 16
Keep us updated 🙂
