hasey66
Message 11 of 19
Re: Speeds down with BT Plus - Help Anybody?
Oh great ! Wonderful !
Message 12 of 19
You never had it before so it won't make any difference that you haven't got it now.
hasey66
Message 13 of 19
So Distinguished Sage - I understand physics and line speed degeneration and why I'm not firing at the top of the range but would be grateful for your enlightened thoughts and explanation as to what's happened and why I've had the reduction in speeds along with lots of others on this forum and whether I'm likely to get them back again ?
Message 14 of 19
as I said previously any connection information you can get from your router - connection speed, max attainable speed and noise margin + more if there is anymore
I am also on ECI so not the end of the world
Message 15 of 19
The move to BT Plus resulted in a DLM reset to an open profile. Once DLM has figured out the best speed your line can support, it will apply the necessary options to achieve it. With an Huawei cabinet, one of those options would have been to apply G.Inp but that is not the case with ECI, however you didn't have G.Inp previously in any case. It can also apply interleaving which should improve your speed. It might decide your line is suitable for a 3dB noise margin rather than 6dB.  It might be that your line was previously running at a higher speed than it should have been but not enough for DLM to take action to reduce it but now DLM has started again from scratch it may set your speed lower. Give DLM time to take action, @stereohaven in the other thread you have posted on has seen his speed return to previous levels.
hasey66
Message 16 of 19
So I am very impatient - let it be said before we start..
This morning saw me rock in at 41 and just now 43 via Speedtest Net and BT Speedtest says 46 coming into the house.
Humble Pie eaten 🙂
Message 17 of 19
Smiley HappySmiley Happy
Message 18 of 19
@hasey66
JerryLee
Message 19 of 19
Hi
I have same issue - see my thread.
2 weeks, only interrupted connection when Openreach using test socket ... did not improve at all when left.  still 33 mbps was 45+ before the "upgrade"
https://community.bt.com/t5/BT-Fibre-broadband/Why-would-quot-upgrade-quot-from-Infinity-1-to-Superf...
