Mjconnolly
Message 1 of 7
Speeds dropped, can mods check profile?
My fibre broadband has been rock solid at 48mb down for months... Until just recently when it has dropped to 33mb with 6.7mb up. Can one of the mods such as @JohnC2 take a look or do I need to raise a support ticket?
6 REPLIES 6
Message 2 of 7
Re: Speeds dropped, can mods check profile?
Can you post the stats from your hub/router
have you tried quiet line test to check for line noise. Dial 17070 option 2 should be silent and best with corded phone
as your profile is based on your connection speed if your connection has reduced then profile would reduce accordingly. To get higher profile you need faster speed
have you been suffering drops in your connection? Often?
Mjconnolly
Message 3 of 7
Hi, here are the stats (I rebooted the router this afternoon to see if that improved things - it didn’t).
Product name:Smart Hub
Serial number:+088047+1825004357
Firmware version:v0.09.06.05093-BT
Firmware updated:Tue Dec 18 14:32:48 2018
Board version:01
DSL uptime:0 days,02 Hours08 Mins57 Secs
Data rate:6.845 Mbps / 39.998 Mbps
Maximum data rate:6.845 Mbps / 64.711 Mbps
Noise margin:5.8 / 18.5
Line attenuation:33.7 / 23.2
Signal attenuation:22.4 / 21.6
A quiet line test seemed fine. Looking back at the event log, there have been 8 disconnections in November, 6 in October, and 8 in September, and they were nearly all in the early hours of the morning - between 1am and 4am - so I never noticed. The profile was knocked down to 44mb on the 7th of November, and then 40mb on the 12th of November, and it’s stayed there since.
Message 4 of 7
All the drops and manual resets of the connection have resulted in your connection ending up in a banded profile. If your connection continues to drop then speed will drop even further and noise margin get  higher
have you tried connecting to the test socket with a filter to see if that improves your line stability by eliminating your internal wiring and the faceplate
Mjconnolly
Message 5 of 7
The router is already connected to the master socket, which is the latest Openreach model (fitted in March). I have only manually disconnected once. I’ll raise a ticket.
Message 6 of 7
Trying test socket even if you have a filtered master socket should be tried to ensure problem on on your side of test socket and you get charged £85 for engineer callout
Your connection has dropped more than 1 reset check your hub logs  filter to WAN
Mjconnolly
Message 7 of 7
Yeah, I’ll give that a whirl in the morning. I always filter the log to WAN anyway.
