JohnC2
Moderator
Moderator
Message 21 of 23
Re: Speeds halved since migration to new closer cabinet
Hi @KyleMac  have you been able to test with a BT hub and are you still experiencing speed issues?
cheers
John
KyleMac
Message 22 of 23
@JohnC2 The Smarthub immediately fixed it and it's still fixed even with the HG612 back in. So I think it just needed another resync for the profile change to fully kick in.
After plugging in the Smarthub the cabinet also started dropping the SNR target below 6 so maybe that's related.
JohnC2
Moderator
Moderator
Message 23 of 23
Hi @KyleMac  thanks for posting back and glad to hear you are now seeing the speeds you expected. I'll now close the case.
cheers
John
