DarloCol
Message 1 of 10
Star plan 1a and new 5c master socket
I have a an ancient wiring configuration that I think is known as Plan 1a or star plan. There are 4 separate cable runs from an outside grey box, one of these doesn't go to any socket I can find, another two are terminated on early BT "plug-in" boxes and the 4th leg has a more up-to-date line box used for Infinity broadband. A few months back, an engineer called to correct an identified line fault and he replaced the Infinity front plate with a mark 2 version of the latest Openreach 5c. Speeds improved for a while, but have progressively fallen from 50+ Mbs down to 18Mbs. (I'm paying for upto 70).
Having done some research, I see star wiring can cause issues with FTTC infinity and that it is usual for engineers to advise removal of the star wiring when installing infinity.
I'm wondering if the last engineer ought to have done that and if I now request another visit, whether I'll be expected to pay for it?
Any advice would be appreciated.
9 REPLIES 9
imjolly
Message 2 of 10
Re: Star plan 1a and new 5c master socket
Really surprised last engineer did not rewire the outside master to avoid the star wiring I would get engineer visit to sort out the wiring
Starwire2000
Recognised Expert
Message 3 of 10
If he’s fitted an SSFP onto the NTE Socket it’s possible it’s not Star Wired but Back Wired?
Or it could be the Engineer was new and wasn’t aware to check for Star Wiring. This wouldn’t surprise me as the training provided to New Recruits is really **bleep** poor.
Then again it could be the Engineer saw the Star Wiring and couldn’t be arsed as he wanted to go home early and just pretended he didn’t see it.
DarloCol
Message 4 of 10
Thanks for this.
The faceplate says "Openreach MK4"
Don't know if that clarifies anything.
I'm one step up from Father Ted's Dougal in these matters.
imjolly
Message 5 of 10
normally all your internal connections would come from the master socket whereas in your case you have extensions coming from the outside socket where the openreach incoming wire meets your internal connection.  this is star wiring and causes problems with broadband  you need to engineer to rewire the external master to get rid of star wiring
in normal connections if you take front plate of the master and connect to the test socket which you can now see you should only get a dial tone at that socket and any other socket should be 'dead'  in star wiring the sockets would still have a dial tone
DarloCol
Message 6 of 10
Thank you imjolly.
So if it just "looks" like star wiring because it's backwired as suggested as a possibility by starwire2000, then all of the sockets on all of the legs should not have dial tone when the front plate is removed at the master?
imjolly
Message 7 of 10
if the engineer made the correct changes to the outside master then yes if you remove the front on the MK5c then there should be no dial tone at any extension socket
DarloCol
Message 8 of 10
Many thanks to the guys who replied here. Armed now with a better understanding of the wiring issues, I have been able to carry out the suggested checks.
Fair play to the engineer who attended last Autumn, it seems he DID back wire the master socket to the outside master junction box. (I just wish he had told me he had done it).
So my current issue is not a repeat of previous problems, but (it seems) is probably a hub issue.
Thanks again guys.
DarloCol
Message 9 of 10
Just to complete the saga; turns out the joint in the outside box was the problem. Heavily corroded and a new cable is to be pulled through....
imjolly
Message 10 of 10
great - thanks for update
