VishalM
Message 1 of 12
Still getting full speeds despite 3 extensions + star wiring?
I’m currently on the 76 download package. I have 4 extensions with star wiring but I still get full speeds of 76.
should I remove the extension wiring even if I’m getting full speeds? I thought having more extensions and star wiring deteriorates your speed but I’m still getting the full 76?
11 REPLIES 11
Les-Gibson
Recognised Expert
Message 2 of 12
Re: Still getting full speeds despite 3 extensions + star wiring?
If it ain't broke and you're happy then leave well alone
♪♪I don't work for BT, I offer my time and help for free. If you'd like to leave a kudo, you may do so by clicking the rating button below.♪♪ 😄
VishalM
Message 3 of 12
Haha I’m just curious as to why people say star wiring is bad when I’m getting full speeds on star wiring for 4+ extensions
imjolly
Message 4 of 12
where are the extensions connected if not master - maybe a junction box where incoming openreach wiring connects to internal wiring
VishalM
Message 5 of 12
My wiring is as follows:
Master socket -> junction box (no 5 terminal) upstairs -> 3 extension cables. On my no 2 terminal I have a downstairs extension
imjolly
Message 6 of 12
if the incoming openreach connection goes first to your master and then to junction box which then feeds your extension wiring then that is not star wiring.  star wiring happens when you connect your extensions  before the master socket
Les-Gibson
Recognised Expert
Message 7 of 12
Star wiring isn't considered good practice but at the end of the day it's the REN (Ringer Equivalence Number) that's important. This depends on the REN of each connected device, the number of devices connected, and, if the jobs been done completely wrong, the number of master sockets you have (there should only be one)
VishalM
Message 8 of 12
How is it possible to get an internet connection by connecting the extension sockets before the master socket? There’s no a and b terminal on the extension sockets??
imjolly
Message 9 of 12
From your post I assume your extensions are all connected after the incoming openreach cable is  connected to terminals A&B in master socket  - probably a connection from terminals 2&5 in master to one or more of your extensions  this is not star wiring
VishalM
Message 10 of 12
Yes that is correct. So star wiring would be incoming openreach cable - junction box - extension and then from the extension the master socket is connected?
