kitkat388
Message 21 of 203
Re: Still not gettimg around 40mb
Hi Jedi188
Sometime we got to hope on our Luck. hoping BT will send a good engineer out on your visit. I think you are really unlucky on your last Engineer visit. Hope they will send in a good one tomorrow for you.
Yes I know what you mean on above. When My infinity install on the day the Engineer show me on his device I can get around 40 download speed.
as you said it could be between the socket to the hub!!!!
cheer,
jedi118
Message 22 of 203
Well, I'll post the results tomorrow
kitkat388
Message 23 of 203
After tomorrow if nothing sorted then we may able to thinking about its could be the anti -virus problem !!!
we can then may try and uninstall it and see if it sort the problem
carvell
Message 24 of 203
For what it's worth, I can confirm it's nothing to do with your PC, or any anti-virus.
I have confirmed the problem connected directly into the homehub, running a Ubuntu live cd.  So it's nothing to do with windows, the homehub, or any kind of anti virus.
Good to see that the BETA speed test reports full speed for you too, kitkat388.
There's clearly a widespread problem that they're not aware of (certainly not the person I spoke to anyway).
Out of interest, where are you both located?  I'm in Cheltenham.  Wonder if it's something to do with the exchange?
jedi118
Message 25 of 203
Well i for one wont be letting the engineer leave until its sorted out!! So hopefully I will be able to post positive news tomorrow. Are you tempted to unistall norton tonight
jedi118
Message 26 of 203
I'm Cheltenham too!!!! Ok this may nail it down a little!
kitkat388
Message 27 of 203
Hi Carvell
thanks for your confimed so we can crossed out the Anti -virus problem !
I'm in Derbyshire.
WE just got to hope one of you two got it sorted by the Engineer then post it here .
kitkat388
Message 28 of 203
is Derbyshire far away from Cheltenham ???
jedi118
Message 29 of 203
Yeah miles away from each other. Cheltenham has always had **bleep** issues with the cabs , it could be that which is an issue but my last engineer would not get the 40/10 results??? I bet BT are capping the speed
carvell
Message 30 of 203
Certainly seems like they're capping it, yeah.
The person on the phone refused to admit there was a fault, because the BETA speed test was max speed.
If they purposely let the BETA speed test go at full speed, but cap all other traffic, then claim it's all OK because the BETA speed test is full speed then that's really, really bad of them.
This is obviously all speculation at the moment though. Could be a genuine fault that they're not aware of.
