kitkat388
Message 51 of 203
Re: Still not gettimg around 40mb
hi Carvel
Let's see what your engineer going to says on Friday. Hopefully he is the one in the big forest able to answer our big Questions of our speed.
Please don't hesitant to post if it postive or negative news from that engineer visit.
thanks
kitkat388
Message 52 of 203
Hi Jedi188
Thanks for your post about the engineer visit this morning. unfortunetly he is not theone able to answer our question!!!
Let's hope Carvel friday Engineer visit is the person able to answer our question and give our a solution!
carvell
Message 53 of 203
Unfortunately I am of the opinion that it's out of the engineer's hands.
As far as they are concerned, the line is working fine and there are no fualts, which is probably true.
The problem is with the speed cap that is being applied. It would appear that neither they (nor anyone) can shed any light on that.
I've contacted the mods regarding the issue so hopefully they'll be able to do some digging at BT HQ.
BattFink
Message 54 of 203
@carvell wrote:
Battfink, can you try the BT BETA speed test and see what that says? The button says "Above 24Mbps BETA Test" or something like that.
I normally get 35 (very occasionally get 37ish) on the beta speedtester as well, so it looks like the same problem
kitkat388
Message 55 of 203
Hi Carvel
Let us know what the mods says about the issue we all thinking ( speed capped).
Once you post what the Mod said , I got one thing in my mind we may able to try at the very end if no one else can help.
I not sure if it work and its costly. so really don't want to try it till the end.
thanks
jedi118
Message 56 of 203
pre tell .....come on , spill the beans
Guru
Message 57 of 203
A lot of people in B.T Infinity is having problems with the B.T Speedtester.
Maybe a MOD could escalate this somehow to see if there really is a problem with customers BB or the Speedtester itself.
If you want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side If the the reply answers your question then please mark as ’Mark as Accepted Solution
BattFink
Message 58 of 203
It's not an issue with the speedtester (although it does appear to be lying), it's an issue with the ACTUAL the real world throughput of the line, it's capped at 20 odd Mb/s, time of day doesn't appear to matter, the router isn't an issue as I've tried this directly connected to the modem & tried different routers (Draytek 2850).
(I know it's not the other end as I've tried pulling a file off my works private FTP server which is on a 1Gb/s line)
Modem is synching to the cabinet at 140,000ish kb/s
I've exhausted all local testing that can be done, it appears there is a problem upstream. Now it appears there are mulitple people with exactly the same problem...
jedi118
Message 59 of 203
.....and its an issue that seems to not be getting an answer!
Moderator-Retired
Message 60 of 203
More than one person getting a similar speed issue doesn't necessarily mean it's the exact same problem, especially if you're all in different areas. For us to work out what's going on we'll need your details, so if you haven't already done so please fill out our contact form and we can see what's what with each of your lines. Please try to include the results of a BT speedtest ran today on a computer directly connected to your Homehub via an ethernet cable (i.e. no powerline adapters or switches or other networking equipment) as well to speed up things a bit.
*edit* if you can confirm whether or not the issue exists on more than one computer it will also help.
Dean
BTCare Community Mod
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side of the post.
