jedi118
Message 71 of 203
Re: Still not gettimg around 40mb
I think I am going to disable it when I get home tonight. Is it easy to turn off Norton or shall I uninstall?
Cheers all
Guru
Message 72 of 203
No just turning it off should be fine, don't think an uninstall is necessary.
If you want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side If the the reply answers your question then please mark as ’Mark as Accepted Solution
D-ave
Expert
Message 73 of 203
Cheers all
Just to add, I found out a while ago that some Internet Security progs interfere with speedtest results (presumably it's because they want to check the file is safe, and won't let it through until they have done so). In Kaspersky if you right-click on the taskbar icon, there is a "Pause Protection" option and there may well be something similar in Norton, either via the taskbar or by opening the program itself.
I always do all my speedtests with protection paused/suspended.
jedi118
Message 74 of 203
Sadly turning off norton did not work either
Guru
Message 75 of 203
Do you have any other applications running, that are computer thirsty as i would say. Sometimes this can affect this, other than that hopefully Dean can shed some light on the subject.
jedi118
Message 76 of 203
Nope, my CPU is at 2% and pf usage is 630 mb, so my ov is running smoothly
carvell
Message 77 of 203
For what it's worth, I've ruled out anything to do with PC hardware by using 3 different PCs and a linux live cd on my end.  I've tried this plugged directly into the openreach modem too, bypassing the homehub.  In all cases the problem was identical and the same as jedi118's.  The connection goes at 35Mb with the BT BETA speed test, but won't exceed 20Mb doing anything else.
I have also ruled out a false result from the BETA test by monitoring network throughput - as is evident from a screengrab I posted in page 4.
Guru
Message 78 of 203
The only thing i would suggest is to get your Hub and/or Openreach modem replaced and go from there, and then they can see if it's an external problem.
jedi118
Message 79 of 203
Hi aarong, got both bits of kits replaced with no change!
kitkat388
Message 80 of 203
seem to be no luck for all of us who stuck at 20mb : (
