Message 1 of 6
Strange HomeHub stats
Hi
I've recently upgraded (this morning) my Infinity 1 to 2 (or whatever its called this week) and my hub is displaying some rather strange stats. The noise margin on my old infinity 1 package was 6db, previously when i had the 80mb service before it would happily sit at 3db giving me just under the max 80mb connection and a 16ish mb upload speed. The margin now seems to have jumped up to 12db. Is this just a hub error or is there likely to be something bigger at play here?
Data rate:18.775 Mbps / 48.964 Mbps
Maximum data rate:24.555 Mbps / 79.852 Mbps
Noise margin:11.3 / 12.4
Line attenuation:10.1 / 15.9
5 REPLIES 5
Message 2 of 6
Re: Strange HomeHub stats
as you have changed package the DLM has been reset so you need to let connection settle and speed should return to 'normal'    if your noise margin was at 3db the suggests you had G.INP activated so might take a bit longer for that to happen
Message 3 of 6
Is it likely that both the upload and download will drop slightly as this happens? Since i last had 3db I’ve returned to ads then back up to fibre (long long story) so I suppose we will see what happens.
Message 4 of 6
Just maintain connection and let DLM sort out connection
Message 5 of 6
Thanks imjolly. Left it alone for as few days and a big improvement on data rate
DSL uptime:0 days,03 Hours43 Mins26 Secs
Data rate:19.999 Mbps / 79.999 Mbps
Maximum data rate:26.049 Mbps / 83.646 Mbps
Noise margin:15.5 / 5.5
Signal attenuation:10.1 / 20.6
Message 6 of 6
great connection now and no effort required
