MattC24
Message 11 of 18
Re: Sudden download speed issues
All good at the moment so will try again when speed drops.
Message 12 of 18
That test seems fine at the moment.
MattC24
Message 13 of 18
Yep it's working ok. We are off out now so will try again later on when we return.
Moderator
Moderator
Message 14 of 18
Hi @MattC24 Sorry you are experiencing slow speeds. I've checked and we have no reports of your congestion in your area. Please complete the speed test as requested by Keith and post the results and we will be happy to advise you further then.
Cheers
John
MattC24
Message 15 of 18
Thanks Keith and John.
Speed is starting to drop now so have run another test. Although not down to 0.5mbps but i will not likely be able to run the test then.
1. Best Effort Test:  -provides background information.
 Download Speed
 9.01 Mbps
0 Mbps77.34 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 9.01 Mbps
 For your connection, the acceptable range of speedsis 40 Mbps-77.34 Mbps .
 Additional Information:
 IP Profile for your line is - 77.34 Mbps
2. Upstream Test:  -provides background information.
 Upload Speed
 15.72 Mbps
0 Mbps20 Mbps
Upload speed achieved during the test was - 15.72Mbps
 Upstream Rate IP profile on your line is - 20 Mbps
This test was not conclusive and further testing is required.This might be useful for your Broadband Service Provider to investigate the fault.
Moderator
Moderator
Message 16 of 18
Hi @MattC24,
Thanks for doing all of that for us. We'll need to test your line ourselves and take it from there. To reach us, click on my user name and then on "Click here to contact the mods". That'll let you complete a web form and send it to us.
DanielS
MattC24
Message 17 of 18
Thanks @DanielS have contacted you as requested.
Moderator
Moderator
Message 18 of 18
@MattC24 I called there but missed you, I wanted to follow up and ask if you're happy to close the fault as all my checks indicate no further problems since you've installed the new hub. Please can you drop me a reply to let me know?
