nobby1963
Message 1 of 9
Sudden speed drop infinity2?
Any idea why I would suddenly get a drop overnight from 76-77 down to 53-54? I’m around 150mts from the cabinet and it’s not missed a beat since being installed almost a year ago. All extensions disconnected. I’ve been on to support and an engineers calling. Wondering what the causs might be.
8 REPLIES 8
nobby1963
Message 2 of 9
Re: Sudden speed drop infinity2?
nobby1963
Message 3 of 9
21:20:30, 18 Jun.,:WAN: SENSING AUTO VDSL
21:19:59, 18 Jun.,ptm0.101:VLAN VLAN_DATA connected
21:19:59, 18 Jun.,:connection ATM_TV disconnected.[ERROR_USER_DISCONNECT]
21:19:59, 18 Jun.,:connection ATM_DATA disconnected.[ERROR_USER_DISCONNECT]
21:19:59, 18 Jun.,dsl:VDSL link Up: Down Rate=59863Kbps, Up Rate=19999Kbps, SNR Margin Down=0.00dB, SNR Margin Up=6.00dB
21:06:01, 18 Jun.,:VLAN VLAN_DATA disconnected
21:05:55, 18 Jun.,dsl:VDSL Link Down: duration was 218 seconds
21:02:49, 18 Jun.,:WAN: SENSING AUTO VDSL
21:02:17, 18 Jun.,ptm0.101:VLAN VLAN_DATA connected
21:02:17, 18 Jun.,:connection ATM_TV disconnected.[ERROR_USER_DISCONNECT]
21:02:17, 18 Jun.,:connection ATM_DATA disconnected.[ERROR_USER_DISCONNECT]
21:02:17, 18 Jun.,dsl:VDSL link Up: Down Rate=59955Kbps, Up Rate=19999Kbps, SNR Margin Down=0.00dB, SNR Margin Up=6.00dB
20:59:21, 18 Jun.,:VLAN VLAN_DATA disconnected
20:59:14, 18 Jun.,dsl:VDSL Link Down: duration was 3018 seconds
00:01:55, 01 Jan.,:WAN: SENSING AUTO VDSL
00:01:29, 01 Jan.,ptm0.101:VLAN VLAN_DATA connected
00:01:28, 01 Jan.,:connection ATM_TV disconnected.[ERROR_USER_DISCONNECT]
00:01:28, 01 Jan.,:connection ATM_DATA disconnected.[ERROR_USER_DISCONNECT]
00:01:28, 01 Jan.,dsl:VDSL link Up: Down Rate=62376Kbps, Up Rate=21372Kbps, SNR Margin Down=6.90dB, SNR Margin Up=6.30dB
00:00:24, 01 Jan.,:WAN: ethernet as LAN
00:01:57, 01 Jan.,:WAN: SENSING AUTO VDSL
00:01:22, 01 Jan.,ptm0.101:VLAN VLAN_DATA connected
00:01:22, 01 Jan.,:connection ATM_TV disconnected.[ERROR_USER_DISCONNECT]
00:01:22, 01 Jan.,:connection ATM_DATA disconnected.[ERROR_USER_DISCONNECT]
00:01:22, 01 Jan.,dsl:VDSL link Up: Down Rate=59710Kbps, Up Rate=21584Kbps, SNR Margin Down=7.10dB, SNR Margin Up=6.00dB
10:29:32, 18 Jun.,dsl:VDSL Link Down: duration was 1211349 seconds
10:29:32, 18 Jun.,:VLAN VLAN_DATA disconnected
01:31:41, 06 Jun.,:WAN: SENSING AUTO VDSL
00:01:46, 01 Jan.,:WAN: SENSING AUTO VDSL
00:01:15, 01 Jan.,ptm0.101:VLAN VLAN_DATA connected
00:01:15, 01 Jan.,:connection ATM_TV disconnected.[ERROR_USER_DISCONNECT]
00:01:15, 01 Jan.,:connection ATM_DATA disconnected.[ERROR_USER_DISCONNECT]
00:01:14, 01 Jan.,dsl:VDSL link Up: Down Rate=83048Kbps, Up Rate=29655Kbps, SNR Margin Down=15.30dB, SNR Margin Up=6.40dB
00:00:23, 01 Jan.,:WAN: ethernet as LAN
09:58:49, 04 Jun.,dsl:VDSL Link Down: duration was 1210642 seconds
09:58:48, 04 Jun.,:VLAN VLAN_DATA disconnected
00:01:40, 01 Jan.,:WAN: SENSING AUTO VDSL
00:01:14, 01 Jan.,ptm0.101:VLAN VLAN_DATA connected
00:01:14, 01 Jan.,:connection ATM_TV disconnected.[ERROR_USER_DISCONNECT]
00:01:14, 01 Jan.,:connection ATM_DATA disconnected.[ERROR_USER_DISCONNECT]
00:01:14, 01 Jan.,dsl:VDSL link Up: Down Rate=83388Kbps, Up Rate=29747Kbps, SNR Margin Down=15.30dB, SNR Margin Up=6.50dB
09:39:54, 21 May.,dsl:VDSL Link Down: duration was 1046274 seconds
09:39:53, 21 May.,:VLAN VLAN_DATA disconnected
00:01:56, 01 Jan.,:WAN: SENSING AUTO VDSL
00:01:25, 01 Jan.,ptm0.101:VLAN VLAN_DATA
Message 4 of 9
can you post stats from your hh6  advanced settings then technical log information
from what you have posted your conenction is dropping and that is more than likely the cause of the drop in connection speed
try quiet line test  dial 17070 option 2  should be quiet and best with corded phone
nobby1963
Message 5 of 9
Product name:
No noise on quiet line test.
BT Hub 6A
Serial number:
+084316+NQ71512210
Firmware version:
SG4B1000B540
Firmware updated:
21-May-2018
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
0 Days, 14 Hours 35 Minutes 3 Seconds
Data rate:
20.00 Mbps / 61.32 Mbps
Maximum data rate:
21629 / 62361
Noise margin:
7 dB / 6.1 dB
Line attenuation:
10.7 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
8477 MB Uploaded / 12123 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Not active
2.4 GHz wireless network name:
BTHub6-CQSG_2.4
2.4 GHz wireless channel:
Smart (Channel 11)
5 GHz wireless network name:
BTHub6-CQSG-5
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
F4:6B:EF:1A:AA:43
Software variant:
Boot loader:
7.33.1
nobby1963
Message 6 of 9
So an engineer has been. He says it’s a strange one and has done a hard reset of my router and left, it’s still the same. He says he will request a reset of the line with BT. I mentioned I read a reset was done in the cabinet but he said he’s a contractor and not aloud to touch anything outside or go in the cabinet. Waste of time him coming by the look of it. He also said the previous 15.3dB noise margin I had was bad and it should be no more than 6. Connections been perfect since last August with 76-77mb download.
Moderator
Moderator
Message 7 of 9
@nobby1963 the engineers have to contact an office to request a DLM reset even Openreach ones. Have you noticed a speed increase yet?
nobby1963
Message 8 of 9
Thanks for the reply. No change yet
nobby1963
Message 9 of 9
Slight increase this morning with noise margin now at 3db down does this mean it’s been reset? Would a line reset change the downstream noise back similar to where it was before at 15.3db and 77.2mb profile? I can see a delayed fault fix showing in my BT.
