Ryan1502
Newbie
Message 1 of 2
Super Slow BT Infinity NEED HELP
Hi there,
Over the past 2 weeks, my BT infinity 1 has been very slow and drops out frequently. It usually sits at 50.02mbps download 8 mbps upload and 26ms ping which is fine. Currently it is at 18mbps (drops to 1 then disconnects) download 1mbps upload and 50 ms ping! I had an engineer round and he was no help and did nothing apart from change the wall socket face to a newer one which did nothing. My guaranteed speed is 32mbps. I am stuck. Used so much mobile data the past few weeks, can anyone please help me? I don't know what to do! Thanks
1 REPLY 1
Message 2 of 2
Re: Super Slow BT Infinity NEED HELP
if you have a HH5 can you go to hub manager then trobleshooting then helpdesk and post 1-12
can you run btspeedtester and when first test completes then run diagnostic test and post results  must be done with wired connection  btspeedtester
can you enter your phone number and post results  remember to delete number wholesale FTTC check
try quiet line test   dial 17070 option 2  should be quiet and best with corded phone
