I'm on superfast Broadband with a smart hub. This is the speeds I'm getting most of the time. Have looked at my package & it states that its unacceptable if below 1mbps! Surely this isn't classed as superfast?
are you using wireless to run the btspeedtest? if so try it wired
if hh6 then post stats from advanced settings then technical log information if hh5 then troubleshooting then helpdesk
enter your phone number and post results remember delete number https://www.dslchecker.bt.com/adsl/adslchecker.welcome
try quiet line test dial 17070 option 2 should be silent and best with corded phone
Hi thanks for the reply. The results are from a wired device. Download speed down to 0.48, upload 0.37 & ping latency 986 when last taken
As you can see from checker results you estimated connection speed range is 6.5/2.5mb showing g you are a very long way from your street cabinet
What about hub stats and quiet line test
The line was silent
your connection speed at 3.7mb is within your estimated range from dslchecker and as almost at attainable seems no more there
are you using the test socket with a filter to see if that improves speed? try quiet line test from test socket
Hi I've been monitoring the broadband speeds now for a couple of days & they have been ranging from download 0.1 to 2.88, upload 0 - 0.73. This is not a fault as always been the same as like you say we are a very long way from the cabinet. We have complained on several occasions but to no avail. Other residents in our village have same speeds.
BT are texting as raised an issue but each time I answer, I get a different person who then asks the same questions. The last text I got is a complete joke! - 'Hello this is Nasir from BT here. I am sorry for the inconvenience caused you due to slow internet speed. I can understand how frustrating it is. However, I have conducted the line test but could not see any error with our network. Your package minimum guaranteed speed is 20Mbps but as per my line test , from exchange till the premises your HUB is getting a speed of 35Mbps. Its mean there is no any issue with speed externally.'
I have answered back stating my package promise is 2Mbps - 6Mbps but not heard anything back yet.
@Mand123 You still haven't answered if you are using wired or wireless to check speed.
I have completed all speed tests on a wired device
