Message 11 of 34
Re: Superfast Fibre 1 Unlimited upload speed dramatic change
@PeterY1 wrote:
No noise.
In that case, I will ask a moderator to help.
PeterY1
Message 12 of 34
Moderator
Moderator
Message 13 of 34
Hi @PeterY1,
We'll look into this for you. To get in touch with us, click on my user name and then copy and paste the link under "Moderation Team Email Address" into your browser.  Complete that form and we'll get back in touch with you.
DanielS
Community ModeratorDannyS
Show your appreciation!
Click on the thumbs up next to a reply to say thanks
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
PeterY1
Message 14 of 34
Thanks Daniel
Moderator
Moderator
Message 15 of 34
Hi @PeterY1 I called there but missed you. Wholesale won't progress the fault without an engineer attending, I have pushed back on this several times but the won't budge. I've booked the first available appointment for Monday between 8am and 1pm. Can you reply letting me know if that suits as I can change it if needs be?
Community ModeratorNeilO
Kudos”
PeterY1
Message 16 of 34
Hi Neil
Thanks. Can we make it Friday 18th if that's possible please?
Many thanks
Pete
Moderator
Moderator
Message 17 of 34
@PeterY1 Yes  that's no problem at all, the appointment has been changed to the 18th AM slot.
Kudos”
PeterY1
Message 18 of 34
Many thanks
Moderator
Moderator
Message 19 of 34
@PeterY1 No problem, I'll set a reminder for Friday afternoon to check on the engineers report.
Kudos”
Moderator
Moderator
Message 20 of 34
Hi @PeterY1 I called there but missed you, Openreach have repaired the underground fault last week and I can see the upload is slowly increasing. It's not were I would expect it to be just yet so I'll keep monitoring this and will also ask if Wholesale can do anything further to help improve this.
Kudos”
