Grantphil
Message 1 of 3
Superfast Fibre 1 upgrade question
I have a date for an upgrade activation from basic broadband to Superfast at a holiday home. I will only be able to swap the Hub 4 for the Smart hub a couple of days after the activation date as the property will be empty from now until after the date. Will this be ok ?  Thx.
2 REPLIES 2
gg30340
Message 2 of 3
Re: Superfast Fibre 1 upgrade question
It will not be a problem. Just swap them over when you get there.
Grantphil
Message 3 of 3
Thank you. Appreciate you taking the time.
