I have a date for an upgrade activation from basic broadband to Superfast at a holiday home. I will only be able to swap the Hub 4 for the Smart hub a couple of days after the activation date as the property will be empty from now until after the date. Will this be ok ? Thx.
Solved! Go to Solution.
It will not be a problem. Just swap them over when you get there.
