Message 1 of 6
Superfast Fibre 2 available with other providers, not with BT
Hi
I'm currently looking at the possibility of returning to BT after a year with Virgin Media but I had a question regarding the broadband speeds that are showing as available to me.
When I perform a check on the BT site using my postcode, the top option I am offered is Superfast Fibre at 45-50Mb.
When I check other providers who I assume use the same lines (Plusnet, Vodafone, EE) I am available to choose the next level up - the equivalent of BT's Superfast Fibre 2 at 67Mb.
When I use the BT Wholesale availability checker, it shows me that a downstream rate of 69.3 is available and when I was previously with BT I had Suberfast Fibre 2.
I'm wondering if this is normal, or if BT's website is giving me incorrect information?
5 REPLIES 5
Message 2 of 6
Re: Superfast Fibre 2 available with other providers, not with BT
your address will give more accurate information than post code as phone number does not work   https://www.dslchecker.bt.com/adsl/adslchecker.welcome
post results
all ISPs should be able to provide same speed as BT assuming they sell the product
Message 3 of 6
Thanks for the response. Yes I thought the same thing, that all ISPs should offer the same speeds. The address checker on the link you provided shows the available speed ad 69.3Mb.
So I am wondering why all of the other ISPs are offering this, but it is not showing as available to me when I try to order on the BT site?
Message 4 of 6
As you can see from the dslchecker results your Estimated speed range is 71/49mb and you could be anywhere in that range and only after connection will you be able to tell where.  The minimum handback speed is 44mb
the 67mb which appears in adverts is the average speed for superfast 2 but your speed cannot be known until connection
as all ISPs use the same openreach connection the speed should be same whichever you choose
Message 5 of 6
Thanks again for your response.
The thing that's confusing me is that BT is only offering me standard Superfast 50mb package, while I understand that Superfast 2 with 67Mb is a separate package at a higher price.
If I'm paying the lower price for the standard Superfast then I assume my speed will be capped at 50, and I won't be able to go any higher even if my line is capable, is this correct?
Message 6 of 6
Yes,it will be capped at 55M (not 50M).
There have been a few posts on the forum like this, BT seem to be very pessimistic when it comes to estimating possible speed and seem not to let the customer take the chance that it will be higher and order SF2 whereas other ISPs seem to take an optimistic view of potential speeds. Not sure what the answer is.
