FJM54
Message 1 of 22
Superfast Fibre 2 - register of intent
I have just moved into a property. The BT website says I can get Superfast Fibre 2. The computer won't let me upgrade. The BT operator says it is not available and I should register intent. There is no where on the BT that will let me register intent.
Has anyone else had this problem and if so, what did they do ?
21 REPLIES 21
Sage
Sage
Message 2 of 22
Re: Superfast Fibre 2 - register of intent
I'm not sure but I think Openreach ceased the register intent some years ago though I could be wrong.
Enter your phone number HERE and post the result. Remove your phone No before posting but leave exchange and cab number.
FJM54
Message 3 of 22
Sorry, I don't know how to fill in the telephone number, post it and then delete it.
Paul_31
Message 4 of 22
@FJM54 Click on the blue link 'HERE' in pippincp's post and it'll take you to a web page where you can input your number  and then click on 'search'(see first image).
That will generate a report (see second image). Delete or mask your phone number in that report as I've indicated in red and post the contents of the report here for further guidance.
(You can upload images by clicking on the 'Photos' icon that'll you see when composing your reply on this forum).
FJM54
Message 5 of 22
I have got the report but I don't know how to delete the telephone number.......
I have saved it as a picture and deleted the tel number by using paint, but I also don't know how to then add that as an attachment
From my replies, I must sound like a 2 year old, but I very rarely venture onto forums and my knowledge of using them and in particular manipulating downloads etc is almost non-existent.
If you are patient, I am sure I will get there in the end
Paul_31
Message 6 of 22
If you reply to this post you will see some icons above where you type your message. Select the 'Photos' icon (see image) and it should become clear - navigate to where you have stored the image and drag it to the window you are presented with. That should do it Smiley Happy
FJM54
Message 7 of 22
I saw that already but when I clicked on the camera it opns up an option which asks for the source of the image.
I don't know what to to then.....
Paul_31
Message 8 of 22
Have you saved the image on your computer? If not what device?
If it's on your computer save the image to your desktop so that it easily found and drag it onto the window that is presented when you click on the 'Photos' icon.
If it's not on your computer, what device is the image saved on?
FJM54
Message 9 of 22
Paul_31
Message 10 of 22
Looking at that image, my understanding is that Superfast Fibre should be available to you.
That said, hopefully someone with more knowledge about these things than myself will be able to offer further guidance on what you need to do to get the ball rolling.
In the meantime, have you tried this link: https://www.productsandservices.bt.com/broadband/deals/ to see whether you can make progress.
