scott_johnston
Message 1 of 4
Superfast Fibre 2 resyncs
Our hub resynced  at 9.12 / 35.99 speed but the  btw speedtest was showing a upload speed of 15.36. Then we had another resync showing the data rate as 8.64 /49.00.  I was wondering what on earth could be happening?. Now this afternoon had lots of resyncs logs below.
1st resync
1st resync1st resync
2nd resync
2nd resync2nd resync
Hub Logs
17:10:53, 02 Dec.
dsl:VDSL link Up: Down Rate=57548Kbps, Up Rate=8577Kbps, SNR Margin Down=0.00dB, SNR Margin Up=6.00dB
17:10:22, 02 Dec.
dsl:VDSL Link Down: duration was 21 seconds
dsl:VDSL link Up: Down Rate=57392Kbps, Up Rate=8514Kbps, SNR Margin Down=0.00dB, SNR Margin Up=6.00dB
17:09:36, 02 Dec.
dsl:VDSL Link Down: duration was 221 seconds
dsl:VDSL link Up: Down Rate=53006Kbps, Up Rate=8637Kbps, SNR Margin Down=0.00dB, SNR Margin Up=6.00dB
dsl:VDSL Link Down: duration was 7895 seconds
dsl:VDSL link Up: Down Rate=35804Kbps, Up Rate=9116Kbps, SNR Margin Down=0.00dB, SNR Margin Up=6.00dB
14:53:20, 02 Dec.
dsl:VDSL Link Down: duration was 1433 seconds
14:29:27, 02 Dec.
dsl:VDSL link Up: Down Rate=57174Kbps, Up Rate=8693Kbps, SNR Margin Down=0.00dB, SNR Margin Up=6.00dB
14:28:58, 02 Dec.
dsl:VDSL Link Down: duration was 40 seconds
14:28:18, 02 Dec.
dsl:VDSL link Up: Down Rate=56583Kbps, Up Rate=8565Kbps, SNR Margin Down=0.00dB, SNR Margin Up=6.00dB
14:27:53, 02 Dec.
dsl:VDSL Link Down: duration was 97191 seconds
3 REPLIES 3
imjolly
Message 2 of 4
Re: Superfast Fibre 2 resyncs
Try quiet line test. Dial 17070 option 2 should be silent and best with corded phone
are you trying the test socket with a filter to see if that helps stability by eliminating your internal wiring and master socket faceplate
scott_johnston
Message 3 of 4
i tried a quiet line test when i noticed it resyncing and I didn't hear anything and I did a call back test to see if it would resync it didn't.
Matt-S
Moderator-Retired
Message 4 of 4
Hi @scott_johnston,
Welcome back to the Community and thanks for posting.
Sorry to hear that your connection is dropping out.
I've sent you a Private Message with details on how you can get in contact with the mod team so that we can look into this for you.
Matt
