redspelly
Message 1 of 19
Superfast Fibre Plus
I have recently changed over from Sky to BT Superfast with complete wifi on the proviso that BT said i could get minimum of 32 d/l - at the moment i can only get 19 d/l - engineer has been out today and stated that what i have is the best i am going to get and that i should never have been guaranteed the higher speeds as too far away from the exchange - very disappointed is not the word
18 REPLIES 18
redspelly
Message 2 of 19
Re: Superfast Fibre Plus
Message 3 of 19
Hmm, engineer's view seems to be at odds with the checker.
Nothing to do with distance from the exchange in any case, it is the distance from the cabinet that determines speed.
Can you post the stats from your hub when connected to the test socket please.
redspelly
Message 4 of 19
at work just now but ill do when I get home - he recommended I call Bt as they may have to upgrade the port in the exchange - I thought that was the whole point of him coming out today
Message 5 of 19
Engineer speak with forked tongue!!
Moderator
Moderator
Message 6 of 19
@redspelly very occasionally the estimates can be wrong and in that instance you do have the option to cancel the contract without penalty if you're getting below the minimum guaranteed speed.
If you'd like us to look into this and see if there's any scope for improvement please use the 'click here to contact the mods' link in my forum profile to send in your details. You can find the link by clicking on my username.
Community ModeratorNeilO
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
redspelly
Message 7 of 19
7A092455-70B8-4413-AF1B-967929292A42.jpegThese are the hub settings
Message 8 of 19
Can you post the screen at Advanced settings > technical log please? That will show further information.
redspelly
Message 9 of 19
Message 10 of 19
Hmm, there doesn't look to be much room for improvement there unfortunately. I suspect your line may be aluminium rather than copper. If you haven't already done so, I suggest you take up @NeilO 's offer.
