rf82
Message 1 of 36
Superfast Fibre Unlimited - Slow Evening Speeds
I have recently moved into a new house and I am finding a drastic difference between my daytime and evening speeds. Daytime is 30+Mbps which evening and weekends are usually less than 5Mbps but can be as low as 1Mbps. Could this be a case of exchange congestion?
I have included details of a speed test done on BT Wholesale.
35 REPLIES 35
Message 2 of 36
Re: Superfast Fibre Unlimited - Slow Evening Speeds
No btspeedtester results posted
 an you post router stats if hh6 then advanced settings then technical log infirmation
enter phone number and post results. Delete number but leave exchange and cab.  https://www.btwholesale.com/includes/adsl/main.html
rf82
Message 3 of 36
bb speed test.PNGSorry, I am not sure what happened to the attachment. I don't currently have my HH connected as I am using my own router. I see the same results when I do, though.
Message 4 of 36
If you could follow the guidance on this page, it should help.
Action to take when download speed are dropping during peak times
Message 5 of 36
Then post stats from your router and the results from the dslchecker
was btspeedtes done with wired connection not wireless?
rf82
Message 6 of 36
Yes speed test was done on a wired connection. Let me know if you need any further information.
Moderator
Moderator
Message 7 of 36
@rf82 I checked the East Kilbride exchange and there's nothing listed on the congestion report but the SVLAN supplying your service may be located eleswhere.
Can you post your router stats when its running slow and we'll take a look?
rf82
Message 8 of 36
@NeilO here are the DSL stats from my router last night when running slow.
Moderator
Moderator
Message 9 of 36
Thanks @rf82no issues with those stats which is a good indicator its congestion.  Please use the 'click here to contact the mods' link in my forum profile to send in your details and we'll be happy to investigate further. You can find the link by clicking on my username.
Neil
rf82
Message 10 of 36
@NeilO Thanks, I have submitted it.
