Message 31 of 36
Re: Superfast Fibre Unlimited - Slow Evening Speeds
Perhap @JohnC2 can look at the performance monitors, if he still has access to them. Electrical interference would cause CRC errors, which would impact on throughput without affecting actual line speed.
CRC errors cannot be seen on the latest home hubs, but used to be visible from the BT end using Whoosh, but that was before I retired, so I expect things have changed now.
This can be worse when it gets dark, as you can get interference on the line from things like streetlights. plasma TVs, and light dimmers.
rf82
Message 32 of 36
@Keith_BeddoeThanks for the suggestion. I can see CRC errors on my router. I don't have any just now.
I'll check again this evening when doing a speed test.
Message 33 of 36
Excellent, so you will be able to see if that is the cause.
Moderator
Moderator
Message 34 of 36
Hi @rf82, How has your connection been performing at peak times over the last few days? Are you still experiencing slow speeds?
Cheers
John
rf82
Message 35 of 36
@JohnC2The past few evening I have run tests and it lookd to be working well now.
I'll continue to monitor but I'd say it is now resolved.
Moderator
Moderator
Message 36 of 36
Hi @rf82 thanks for checking that and getting back to me. I've closed the case as resolved now and if you need any further help in the future do pop back to the community forum and we will be happy to help.
Cheers
John
