Chromedome73
Message 1 of 6
Superfast Speed Issues
Hi,I've been on Superfast 1 for ages & due to being out of contract I went with Superfast 2.
I am awaiting my new Smart Hub 2 (which was ordered 21st Aug & still showing as ready for dispatch)
Anyway I did a speed test as I haven't done one in a while & I was shocked to see it down to about  34 instead of the normal 70 odd.
I have add a few screen shots of stats etc.....I also did a router restart to see if that sorted things out.
Thanks for looking
5 REPLIES 5
Sage
Sage
Message 2 of 6
Re: Superfast Speed Issues
Your package has been wrongly configured. A mod should be along shortly.
Chromedome73
Message 3 of 6
Thank You
Moderator
Moderator
Message 4 of 6
Hi @Chromedome73 welcome to the forum and thanks for posting. We will be happy to get your broadband corrected. I've sent you a Private message explaining how you can contact the forum moderation team.
Check here: https://community.bt.com/t5/notes/privatenotespage
Cheers
John
Moderator
Moderator
Message 5 of 6
Hi @Chromedome73,
Thank you for taking my call today.
Your connection is looking good now that the order has completed to change you over to the 80/20 service. The tests are showing your sync speed is sitting at 78Mbps.
With regards to the Hub, I'm sorry you haven't received this. I've placed a new order and the hub is due for delivery on the 2nd of September.
PaddyB
Chromedome73
Message 6 of 6
Thanks again for your help @PaddyB
