Message 11 of 15
Re: Superfast fibre 1 unlimited download speed issues
Did you try the quiet line test requested?
are you using a phone extension cable to connect hub to your phone socket?  Have you tried changing the filter?
Message 12 of 15
I don't have a test socket but I did try the test and there was no noise on the line.  My hub of right beside the socket so I am just using the cable that came with the hub. I haven't tried changing the filter. I wonder if getting the socket replaced with one with a built in filter would help ?
Message 13 of 15
What does your master socket look like?
Master socket with one socket
Does your phone line come from a pole, or underground?
Are there any other phone connection boxes in your house?
 Changing for a filtered socket is unlikely to make much difference, if there is no other phone wiring in the house.
Message 14 of 15
My phone socket looks like the one at the end on the right ( number 4) and phone line comes from underground. I don't have any other sockets in the house.
Message 15 of 15
It may be worth carefully checking behind that socket to check that there is only a single pair of wires connected to it and there is no evidence of damp or corrosion..
There should normally be plenty of spare cable to allow you to look behind the socket.
There will probably be one other spare pair of wires coiled up, but they should be insulated, with no bare ends showing, The master socket should look like this.
The working pair of wires, should be on connections 2 and 5, and there should be no other wires connected.
