SnowfirE
Message 1 of 16
Superfast
Hello,
I switched from virgin to superfast fiber with a smart hub 2, but I want to use my own vdsl router.
I configured the settings user and password as bthomehub@btbroadband and the password as bt, but when it tries to connect it says make sure cable is connected, but it is.
Is the settings the same for all the broadband packages?.
Many thanks.
Tags (1)
15 REPLIES 15
Message 2 of 16
Re: Superfast
Did you include .com at the user name?
SnowfirE
Message 3 of 16
Re: Superfast
Of course.
Message 4 of 16
Re: Superfast
I was only going by what you posted!
SnowfirE
Message 5 of 16
Re: Superfast
Yeah my bad.
Message 6 of 16
Re: Superfast
Which router is it? If its the one you used with Virgin are you sure it is a modem/router and not just a router.
SnowfirE
Message 7 of 16
Re: Superfast
tp link vr900 v2
I've used this with bt infinity before I switched to virgin
Message 8 of 16
Re: Superfast
Factory reset it and set it up using the quick setup wizard.
SnowfirE
Message 9 of 16
Re: Superfast
Tried many times
Message 10 of 16
Re: Superfast
Is it definitely Superfast and not Ultrafast delivered by G.Fast?
