Message 1 of 2
Switch to EE Full fibre 1.6gb or move to BT 900mb? Help please!
Hi,
our street has just been activated and I'm able to now take a Full Fibre package.(currently Halo 3+ partial fibre)  In considering matters seems everywhere I look on BT there is messaging about moving to EE. To the point of being guided towards them....I was considering the BT 900mb, but then saw the EE 1.6gb offering.
So a few questions if anyone can help:
1) Can you port Digital Voice/existing number  to EE ?
2) Can I retain my BT Email Addresses? seems to be conflicting info, even from BT Staff I've spoken to.
3) Will EE configuration work with Complete wi-fi discs , I'm currently running 3 in property?
4) Is the EE Smart Hub Pro Router significantly better than HH2?
Really appreciate any guidance or advice. Thanks.
1 REPLY 1
Message 2 of 2
Re: Switch to EE Full fibre 1.6gb or move to BT 900mb? Help please!
In response to your points:
1 - Yes you can port your number no issues
2 - You can retain your email address (It will stay on the BT Account)
3 - The smart WIFI discs will not work with the smart hub pro- you will need a package which includes Smart WIFI pro and you will get new boosters
4 - I very recently made the jump over and have noticed a big difference especially in relation to WIFI speed
