Message 11 of 14
Re: Switched over to ee and wow
Am currently with BT and the smart hub 2, so is it possible to use the EE WiFi 6 or 7 router to use with my BT broadband and would it just be a matter of plug and play ?
Anonymous
Not applicable
Message 12 of 14
Simple answer is yes
Obviously you'll need to change your ssid and password but it's totally compatible.
Loads of new ones on ebay.
Message 13 of 14
Just be aware that if you wanted to use EE wi-fi extenders these are specific to each EE router variant.
Anonymous
Not applicable
Message 14 of 14
True but probably wouldn't need them anymore if going from wifi 5 to 6/7
