Hi,
We've had Infinity for a few years now, always got around 75 Mbps download speeds (we are pretty close to the cabinet), over the last few weeks we are now only syncing at around 60 Mbps which is quite a drop.
Router Stats today:
1. Product name: | BT Home Hub |
2. Serial number: | +068343+NQ33638558 |
3. Firmware version: | Software version 4.7.5.1.83.8.236.1.2 (Type A) Last updated 11/07/17 |
4. Board version: | BT Hub 5A |
5. DSL uptime: | 3 days, 08:17:51 |
6. Data rate: | 18999 / 61744 |
7. Maximum data rate: | 25477 / 59781 |
8. Noise margin: | 9.3 / 5.4 |
9. Line attenuation: | 9.8 / 11.4 |
10. Signal attenuation: | 9.8 / 11.4 |
Does anything look amiss there ?
Ian
Solved! Go to Solution.
strange you have dropped from 75mb down to 60mb and even the max attainable is about 60mb
have you tried quiet line test for noise? dial 17070 option 2 should be quiet
have you tried using test socket with filter to see if that improves your speed?
Hi,
Line test on 17070 is silent.
One thing I meant to add in my original post is that about 6-8 weeks ago BT added another green cabinet at the top of our road (in addition to the one already there), I'm not totally sure, but it seems possible that my speed drop happened at around the same time ?
It might be related - going to 'https://www.productsandservices.bt.com/products/speed-checker/' gives me a message saying:
'BT Infinity is available in your area but due to a high demand there is currently no capacity left at your local cabinet. There will be a waiting period until we can activate the service.
You say my max attainable is 60mb, given the message above - have I been capped somehow because BT don't have enough capacity ? (very annoying if so !)
BT don't cap lines and anyway max attainable would not be affected
My line results from the BTWholesale checker
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Handback Threshold(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
WBC FTTC 18x2 Provide Availability
WBC FTTC 18x2 Sim Availability
Left in Jumper
HighLowHighLow
VDSL Range A (Clean) | 80 | 74 | 20 | 19 | 67.1 | Available | -- | -- | -- | -- |
VDSL Range B (Impacted) | 80 | 57.6 | 20 | 17.6 | 39.8 | Available | -- | -- | -- | -- |
Sorry for the weird formatting but the forum changed my post.
Have you tried using the test socket with filter and see if that helps? If you try it then post stats
Connected using the Test Socket and a filter:
5. DSL uptime: | 0 days, 00:01:45 |
6. Data rate: | 18999 / 61697 |
7. Maximum data rate: | 25886 / 61678 |
8. Noise margin: | 9.7 / 6.0 |
10. Signal attenuation: | 9.7 / 11.4 |
Small improvement but nowhere near back to your 75mb. Looks like engineer visit needed
Ok thanks, can that be arranged from here, I recall in the past a member of BT staff helped me from here once a problem had been established ?
You can just phone customer services and arrange engineer visit. There Is no need for mod involvement as this is straightforward engineer request
