cloudy73
Newbie
Message 1 of 3
Sync rate dropping / Speed Drop
Hi Guys,
Looking for some help, I've got a fault ticket open, but not alot seems to me happening and BT chat ain't working to help update the ticket.
For the benefit of any testing, I've put my BT HH5 back as main router.
So usual sync is 79999/20000, but had dropped to 71000 and now its down to 62000. I do have a low buzz on the quiet line test, hence ticket, and the inital testing did say they had found a fault on the line - but no idea how long this will take for any update. Would an engineer do a line check for the nosie / fault and reset my line to get the full sync back??
Much Appreicated.
2 REPLIES 2
Message 2 of 3
Re: Sync rate dropping / Speed Drop
if there is noise on your line and you reported a phone fault to 151 not broadband then you should ge a phone engineer to sort out the line noise     your connection should start to improve once line noise is fixed but a phone engineer will not organise a line reset
BT TV Expert
BT TV Expert
Message 3 of 3
Hello,
Sorry to hear your broadband speeds are dropping, I could take a look at your line for you. Just send me a private message with your landline phone number, thanks.
Jack
Community ModeratorJack
Show your appreciation!
Kudos”
I am a BT Employee and an expert on TV queries. I am here volunteering my own time to give advice, and help where I can with BTTV queries. Go here for more info.
