LeiaWinston
Message 1 of 8
Sync speed 80 but ipprofile 70?
The hub is connected to the master socket (it`s the only socket, no extensions, only 1 cordless phone base) using a 0.5 metre cable. Also tried the test socket, no improvement there. Could it be a stale or stuck profile, or maybe crosstalk? It`s not a big deal, we`re still happy with the speeds, just curious.
7 REPLIES 7
imjolly
Message 2 of 8
Re: Sync speed 80 but ipprofile 70?
try running btspeedtester again but use IE/Edge other have been giving odd results
LeiaWinston
Message 3 of 8
Thanks for the reply. All tests have been run with IE using ethernet cable to PC. Actual downloading speeds on the PC never exceed 70. Wi fi speeds only drop a bit to 67-68.
Also, the DLM re-synced 8-9 days ago (possibly due to connecting a newer, thicker dsl cable to the hub a few days earlier), increasing the sync speed from 76 to 80, which also increased the actual speed from 64-65 to the current 68-69. It appears there is always approx 14-15% speed difference between the sync and actual speed.
licquorice
Message 4 of 8
Which is due to the overheads in the different protocols in use. Sync speed will always be greater than download speed.
imjolly
Message 5 of 8
@licquorice  there is something not right as sync speed is 80mb but profile is only 70mb - should be a lot higher
licquorice
Message 6 of 8
True. But the noise margin is only 4.5dB so there is possibly a lot of re-transmission going on which will reduce the download speed further.
imjolly
Message 7 of 8
I saw that as well but profile should be based on connection speed
licquorice
Message 8 of 8
I'm not sure what %age of sync speed the IPprofile is set to for lines with 3dB margin configured, it might be lower than the usual 96.8%.  For DLM retransmission high profiles it is apparently 91% so might be even lower for 3dB profiles.
