pj8210
Message 1 of 3
Sync speed vs actual speed
Hi there,
Wondering if anyone can help. I'm on the 80/20 package, but my IP Profile is 70.61Mbps, despite the router saying it's syncing at the max speed.
The connection is solid, and I'm not getting any disconnections, apart from every 20/30 days or so.
I've posted the HH6 router stats below.
Data rate:
20.00 Mbps / 80.00 Mbps
Maximum data rate:
26495 / 83565
Noise margin:
15.3 dB / 4.6 dB
Line attenuation:
14.9 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
IP Profile is as follows:
The current Downstream BRAS rate is: 70.61 Mbps
The current Upstream BRAS rate is: 20 Mbps
Anyone have any suggestions? It's not a big deal, as 70.61Mbps is still fast!
Thanks in advance.
Paul
2 REPLIES 2
Sage
Sage
Message 2 of 3
Re: Sync speed vs actual speed
Which exchange and cab number?
pj8210
Message 3 of 3
Exchange NAPHILL is served by Cabinet 1
