Message 11 of 15
Re: TP link N600 with BT Fibre
@pdharrop wrote:
I bought one. Set up info would be great.
@pdharrop
I expect that you are viewing this site on a mobile connection, so I will provide a temporary link which you should be able to view the details, as you will not be able to view the main site unless you are connected to BT Broadband.
VDSL (BT FTTC) Setup instructions
Please can you let me know when you have it working.
pdharrop
Message 12 of 15
Thanks for that. I'm not too bad with this kind of stuff but I don't appear to be able to get this to work. The dsl light isn't lit up on the router?
Message 13 of 15
Have BT said that your service has been activated?
I assume you have connected it all up as shown on the diagram on this page?
 Configuration settings for BT Broadband
pdharrop
Message 14 of 15
Yep had texts and emails. Got a dial tone when I plug the phone in. Set it all up as the diagram. Tried restarting and resetting a few times but no joy. I guess I'll have to check with BT that my connection is set up. If they missed the router off my order what else has been missed.
I really appreciate your help. It's making a frustrating situation bearable!
Message 15 of 15
You can usually check the progress of your order via MyBT, and it should show when its been activated.
If you look at the router status page, you should be able to see if initialisation is taking place.
