Message 1 of 2
TalkTalk to BT Changeover Day
Hi,
So I can plan (best guess) my day in advance, has anyone experienced a changeover from TalkTalk? I know BT (infinity 2) say by midnight and everyone is different, but did the TalkTalk (fast Fibre with boost) service get cut off early or remain connected until the changeover? When is it best to change the Routers without too many disconnects to disturb DLM etc.
1 REPLY 1
Zombie
Expert
Message 2 of 2
Re: TalkTalk to BT Changeover Day
Wait until your talktalk router disconnects from the internet then plug in the bt hub. Hopefully it will connect and you will get little down time. I swapped from sky a year ago, I used my sky hub until it went off then I plugged the BT hub in and it connected right away, the only down time I had was the 2 minuets whilst I swapped the hubs over.
