Message 121 of 148
Re: Termination Request.
the max data rate does vary constantly and is nothing to worry about
MarkG33
Message 122 of 148
Ok thanks for sharing that. You would know a fix for the ppp lcp termination requests or openrg rebooting would you?
I've been fighting with this since January this year. It does seem no one has a clue to why it just happens on BTs HH 5 or other BT setups then again not everyone has this issue.
So the saga continues...for me anyway.
*This is my signature...it's a bit boring*
MarkG33
Message 123 of 148
I found a cheap radio lying around. I think its just an analogue radio. All I have on it is to scan or reset the signal. Anyway when I just reset it its silent and doesnt find a station.
So when its placed near on top or near the master socket loud static is heard - If I move it away its pretty much silent and it eventually finds a radio station.
I repeat the process by using the reset button so there is no radio stations picked up and placing it near and on top of the master socket and again loud static until I move it away.
So is that a clue to a possible faulty faceplate, master socket, internal wiring or actual noise on my line? Its the first time I tried this. Any thoughts?
Distinguished Guru
Message 124 of 148
What band was that - AM or FM ?
If not, I'll try again 🙂
MarkG33
Message 125 of 148
It doesnt even say just mini radio lol. But yeah it was a loud static no other part of my living room produced that static except plugs in the power socket but it produced a higher pitched whine rather than loud static near/next to the master socket.
Sorry like I said its a cheap one I have no clue but it can't be coincidence surely.
Distinguished Guru
Message 126 of 148
Well, the modem does operate at radio frequencies so you can maybe hear interference from the modem?
Try it with the modem powered off?
MarkG33
Message 127 of 148
I'm not using the external modem I'm using the HH5 by itself as you can't disable the internal modem unless you connect it up to an external modem. I got it on a high table and when I literally point this cheap-o radio at the master socket below it it emits loud static. It's literally not near the HH5.
I hope that's more understandable as I'm terrible at explaining things.
Distinguished Guru
Message 128 of 148
Sorry, I meant try it with the HH5 powered off.
MarkG33
Message 129 of 148
I tried it turned off and still got loud static so what does  that tell you? Something bad I assume.
Distinguished Guru
Message 130 of 148
Now that shouldn't happen. I suggest you run that past an engineer with REIN training.
