MarkG33
Message 131 of 148
Re: Termination Request.
I assumed it wasn't good lol.
I will chat to the mod I'm in contact with and explain to him what I've been doing and a possible cause of my saga.
I only just recently found out about the radio thing so it will be interesting to see what comes of this. Quiet line test is clear too by the way
Stats as of tonight -
1. Product name: BT Home Hub
2. Serial number: +068343+NQ42338353
3. Firmware version: Software version 4.7.5.1.83.8.173.1.6 (Type A) Last updated 31/07/14
4. Board version: BT Hub 5A
5. VDSL uptime: 0 days, 00:13:53
6. Data rate: 5478 / 39993
7. Maximum data rate: 5562 / 48971
8. Noise margin: 6.1 / 10.3
9. Line attenuation: 0.0 / 24.6
10. Signal attenuation: 0.0 / 22.4
11. Data sent/received: 38.4 MB / 154.6 MB
12. Broadband username: bthomehub@btbroadband.com
Thank you.
*This is my signature...it's a bit boring*
MarkG33
Message 132 of 148
I need someone to clear this up for me about the noise margins.
I saw a fella on here with a high noise margin on both the up and down and was told they both need to be near to 6.0 on both.
Well my up is always spot on 6.0 but my down noise margin varies from 11.5 to the low tens - So would it mean my down noise is an issue? Or do both need to be high to be classed as a problem? I'm confused as I'm being told its fine even though my down noise is way higher and my upstream is on the optimum. How can that be the case?
Distinguished Guru
Message 133 of 148
Who says yours is fine?
If not, I'll try again 🙂
MarkG33
Message 134 of 148
I don't want to name anyone in particular on here but if you look a couple of pages back some seem to think it's nothing to worry about which confuses me.
Distinguished Guru
Message 135 of 148
Ok, well looking at these stats:
you can see that your upstream sync is limited to 5478 by the target noise margin of 6.
The downstream sync is limited to 39993 by the product cap of 40000 on Infinity1.
However looking at this:
Your modem resynced 13 minutes ago. (editted to say resynced instead of rebooted)
Isn't this the problem you started off with?
Distinguished Guru
Message 136 of 148
If you go to Advanced Settings - Broadband - Internet, you can see Connection time: x days, hh:mm:ss
Similarly if you go to Advanced Settings - Broadband - Connection, you can see Connection time: x days, hh:mm:ss
Does this match up with 5. VDSL uptime ?
MarkG33
Message 137 of 148
Actually 13 hours. I guess the seconds didn't get pasted from my HH5 stats lol sorry. Yeah times match up with each other they're both currently on 1 day and 22 hours. There was a time not too long ago the router time was only up for a few hours and the modem was up for over a day.
The longest uptime I get out of the HH5 without an external modem is almost exactly 3 days. With an external modem attached its exactly every 14 days when they both reboot with either setup I get an OpenRG is going down for reboot followed by the PPP LCP Send Termination request [user request] or just the PPP LCP Send Termination request [user request]. I do occasionally get a PPP LCP Send Termination [Peer not responding] Whatever that one is.
Distinguished Guru
Message 138 of 148
Have you had the master socket replaced?
MarkG33
Message 139 of 148
No not yet.
Do you think it's worth trying at some point in future?
The mod I'm in contact with won't be back until Saturday.
Distinguished Guru
Message 140 of 148
Yes, I would replace everything, starting from the router (done) modem (done) cables (done) master socket (tbd) dropwire (tbd) pair to cab (tbd) line card (tbd) lift-and-shift (tbd).
