consmi24
Message 1 of 24
Terrible Internet Speeds (repeating occurrence)
For the past few months, I've been experience horrific fibre speeds (and when I mean horrific, I mean it). There are periods of time when the connection itself is too slow to actually load google, let alone conduct a search. I've been in contact with BT for months over this and, if a record does exist of call outs, there would be numerous times on file which show a BT engineer has been called out and not found a fault at the home address.
It's getting absolutely ridiculous. I was previously getting speeds of around 50mbps and, until recently, my speed range had reflected that. Not only do I get low speeds, but the router drops randomly throughout the day, the longest network up time so far being about 8 hours.
I've just conducted a wholesale test and these are the results:
 Download speedachieved during the test was - 2.4 Mbps
 For your connection, the acceptable range of speedsis 10.72 Mbps-15.32 Mbps .
 Additional Information:
 IP Profile for your line is - 15.32 Mbps
Upload speed achieved during the test was - 8.19Mbps
 Upstream Rate IP profile on your line is - 10 Mbps
These are the stats from the smart hub manager as of 20:34 pm:
T Broadband /
BT Infinity /
BT Infinity 3 and 4 :
BT Infinity
 Downstream sync speed:
17.87 Mbps
 Upstream sync speed:
10.00 Mbps
 Network uptime:
0 Days, 4 Hours 28 Minutes
 Broadband IP address:
86.165.223.23
 Default gateway:
172.16.11.9
 Primary DNS:
81.139.56.100
 Secondary DNS:
81.139.57.100
 System uptime:
0 Days, 23 Hours 54 Minutes
 Serial number:
+084316+NQ84884933
 Firmware version:
SG4B1000E016
 Firmware updated:
24-May-2019
23 REPLIES 23
Sage
Sage
Message 2 of 24
Re: Terrible Internet Speeds (repeating occurrence)
That's the status page, we need the stats from below.
HH6 Advanced settings/technical log/information.
HH5 Troubleshooting/helpdesk.
consmi24
Message 3 of 24
Hi sorry about the delay in response:
Product name:
BT Hub 6A
Serial number:
+084316+NQ84884933
Firmware version:
SG4B1000E016
Firmware updated:
24-May-2019
Board version:
1.0
Gui version:
1.105.0
DSL uptime:
0 Days, 6 Hours 2 Minutes 12 Seconds
Data rate:
10.00 Mbps / 17.87 Mbps
Maximum data rate:
25845 / 43233
Noise margin:
15.2 dB / 21.6 dB
Line attenuation:
20.6 dB
Signal attenuation:
0 dB / 20.6 dB
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
458 MB Uploaded / 3858 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
BTHub6-X2SW
2.4 GHz wireless channel:
Smart (Channel 11)
5 GHz wireless network name:
BTHub6-X2SW
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
30:24:78:C7:3D:97
Software variant:
Boot loader:
9.2.0
Message 4 of 24
Have you tried using test socket with filter?
check line for noise. Dial 17070 option 2 should be silent and best with corded phone
are you using a wired connection when checking download speed?
enter phone number and post results
http://www.dslchecker.bt.com/
consmi24
Message 5 of 24
I'll check the line in the morning, but yes I'm using a wired connection
Moderator
Moderator
Message 6 of 24
Hi @consmi24 I'm sorry to see you're having problems with your broadband speed, have you been able to try the quiet line test yet? Post back and let us know how you get on with that.
Community ModeratorNeilO
Show your appreciation!
Kudos”Kudos”
Message 7 of 24
@consmi24   what about using test socket with filter especially if you have extension sockets in other rooms
quiet line test  your connection speed is low compared to attainable but the 6hrs connection time suggests possible line problems
consmi24
Message 8 of 24
I've just done a quiet line test, and there is some interference on the line, but nothing too loud.
I've tried the test socket and it's getting the same speeds. We have no other extension sockets in other rooms.
consmi24
Message 9 of 24
Bumping because speeds still haven't improved.
consmi24
Message 10 of 24
It's been 11 days since the last post in this, and the speeds still haven't improved.
I'm getting 1.1MB/s download speed, its actually ridiculous now.
