beedoc
Message 11 of 19
Re: Test 3 advises Infinity "Performing poorly"
1. Product name: BT Home Hub
2. Serial number: +068343+NQ51628637
3. Firmware version: Software version 4.7.5.1.83.8.236.1.2 (Type A) Last updated 11/07/17
4. Board version: BT Hub 5A
5. DSL uptime: 12 days, 05:40:31
6. Data rate: 20000 / 79995
7. Maximum data rate: 29316 / 81098
8. Noise margin: 12.4 / 6.1
9. Line attenuation: 13.6 / 13.7
10. Signal attenuation: 13.5 / 13.8
11. Data sent/received: 3.8 GB / 48.1 GB
12. Broadband username: bthomehub@btbroadband.com
24. Modulation: G.993.2 Annex B
25. Software variant: AA
26. Boot loader: 1.0.0
Message 12 of 19
Classic symptoms of congestion, BTWholesale should be aware of the problem from their monitoring and will be taking steps to increase capacity.
beedoc
Message 13 of 19
Can you elaborate? What information leads you to a congestion diagnosis?
Everything looks "healthy" except the download speeds fall way short of the expected and quoted rates.
Message 14 of 19
The fact that your line is syncing at the maximum possible speed for Infinity2 yet your throughput is much lower. Sync speed and download speed are 2 entirely different things, hence needing to see your hub stats.
Moderator
Moderator
Message 15 of 19
@beedoc what exchange are you connected to?
beedoc
Message 16 of 19
ESSTI
Moderator
Moderator
Message 17 of 19
@beedoc there are no reported congestion issues on your exchange. If you send over your details we'll be happy to get this looked into further. You can find the contact the mods link by clicking on my username.
Neil
Sage
Sage
Message 18 of 19
BT Expert
Message 19 of 19
@beedoc
Glad to see the community has helped you get the details and that the Mods have offered to look into your case. You are good hands 🙂
