Message 1 of 4
Test internet speed - BT
I used to test my internet speed on the BT site but have tried today and receive a message that "This service has now closed, but don't worry, our newer even better troubleshooter is now online"!
Following the link it then takes me to a Fault Troubleshooter.
I don't have a fault I just want to check my speed. Using the ones available via google all give me different and really low readings.
Anyone know if i can still check my speed via BT?
3 REPLIES 3
Message 2 of 4
Re: Test internet speed - BT
try
https://speedtest.btwholesale.com/
Message 3 of 4
Hi @Silverhoop   If you have the My BT App then use that. It gives you two readings, speed to Hub and Hub to device.
Message 4 of 4
Thanks for that. Tested it on the app and the speeds are showing what I was expecting
