mrnumbskull
Message 1 of 3
The first 10 days
I had Infinity installed on Friday (22/02). Speeds and reliability so far good. Openreach guy showed me the stats on his tablet and I'm connected as fast as it will go (80/20).
I'm just curious if there is any general advice for keeping things this way, particularly in the first 10 days? The only thing I have noticed is that my ping is a little high, generally 20 - 35ms on speedtest.net - regardless of the test server. Is this likely to change? Does it mean interleaving is on? I used to get pings as low as about 12ms when I was with Be (ADSL2+), though only 11Mbs Smiley Frustrated
2 REPLIES 2
Guru
Message 2 of 3
Re: The first 10 days
If you have 80/20 it's safe to say it will change to Fast path eventually and you will normally see 5ms to uk servers.
Just leave the modem connected 24/7 to maintain the connection at that speed.
If this helped you please click the Star beside my name.
If this answered your question please click "Mark as Accepted Solution" below.
mrnumbskull
Message 3 of 3
Thanks.
