fen666
Message 11 of 14
Re: Totally fed up
Well an engineer turned up while I was out and checked the line and told the Mrs it was ok ... total time 5 minutes .
My final question is why is my ip profile
Download speed achieved during the test was - 6.66 Mbps
For your connection, the acceptable range of speeds 4.8 Mbps-6.86 Mbps .
Additional Information:
IP Profile for your line is - 6.86 Mbps
Upload speed achieved during the test was - 1.01Mbps
Upstream Rate IP profile on your line is - 2 Mbps
When before the fault where my d/l went to 0.26 and the people further down the road lost Internet all together my ip profile for the line was was 8.75 ?
1. Product name: BT Home Hub
2. Serial number: +068543+NQ51439218
3. Firmware version: Software version 4.7.5.1.83.8.204.1.11 (Type A) Last updated 23/07/15
4. Board version: BT Hub 5A
5. DSL uptime: 0 days, 08:38:14
6. Data rate: 1102 / 7086
7. Maximum data rate: 1101 / 8046
8. Noise margin: 6.1 / 8.8
9. Line attenuation: 20.7 / 41.7
10. Signal attenuation: 20.7 / 33.5
11. Data sent/received: 61.7 MB / 668.1 MB
12. Broadband username: bthomehub@btbroadband.com
13. BT Wi-fi: Yes
14. 2.4 GHz Wireless network/SSID: BTHub5-CT6T
15. 2.4 GHz Wireless connections: Enabled (802.11 b/g/n (up to 144 Mb/s))
16. 2.4 GHz Wireless security: WPA2
17. 2.4 GHz Wireless channel: Automatic (Smart Wireless)
18. 5 GHz Wireless network/SSID: BTHub5-CT6T
19. 5 GHz Wireless connections: Enabled (802.11 a/n/ac (up to 1300 Mb/s))
20. 5 GHz Wireless security: WPA2
21. 5 GHz Wireless channel: Automatic (Smart Wireless)
22. Firewall: Default
23. MAC Address: 00:37:b7:2b:d2:6a
24. Modulation: G.993.2 Annex B
25. Software variant: AA
26. Boot loader: 1.0.0
Please note the connection time maximum usually 1 - 2 days before it resets
Message 12 of 14
Re: Totally fed up
your ip profile is based on your connection speed not the other way round so to get a higher profile you need a faster conenction speed
fen666
Message 13 of 14
Re: Totally fed up
So why after 6 months of connecting at 8.75, bb crashes and is faulty for 3 days it is now stable ... though the hub has random disconnects and d/l is a steady 6.66 ?
Message 14 of 14
Re: Totally fed up
your connection speed is 7086kbps but noise margin is high at 8.8db so if you can maintain a stable connection assuming engineer fixed fault then DLM should reduce noise margin which will increase your connection speed   the higher you can get your conenction speed the higher the profile the higher the possible download speed
