Has anyone got the ability in the community to check if the cabinet that serves ab56 4sa is ever likely to get FTTC?
Our small town houses the exchange (Cullen) that also serves a number of tiny villages in the surrounding area.
Yet while even the smallest village with less then 30 residents the exchange serves can now get FTTC the actual main part of town of Cullen cant.
What's worse the main part of our town is where the bulk of businesses, hotels and residents are located.
The only thing the open reach search comes back with is that our cabinet is "under review" which could mean anything in between now or never.
To add insult to injury the exchange is only on ADSL Max for anyone not on fibre.
After months and months of waiting for the exchange to be fibre enabled and now that it has the majority of the residents where the actual exchange is have been left frustrated.
Note: BT say I'm NOT on an EO line.
Solved! Go to Solution.
there is no FTTC shown for that postcode what do you get if you enter your phone number https://www.btwholesale.com/includes/adsl/main.html
When you entered your phone number did it show the cabinet you are connected to?
under consideration basiclly is cost effective and is there a power supply available
Have just ried the Cullen Bay Hotel and it comes up with
Could it be that in the more sparsely populated areas, the vast majority of customers will be connected directly to the exchange ? With the cost of putting in cabinets running into the many thousands, presumably Openreach don't feel that putting in cabinets would be financially viable.......
