Message 1 of 5
Transferring WiFi Password form one BT Hub 2 to a new BT Hub 2
Hi,
I have been sent out a new BT Hub2 to replace my existing Hub 2 which has intermittent problems. Please confirm is there a way to transfer the Wifi password for all my devices on the old hub to the new hub automatically without manually entering the code for each device
4 REPLIES 4
Message 2 of 5
Re: Transferring WiFi Password form one BT Hub 2 to a new BT Hub 2
You simply change the network name (SSID) and the password on the new hub to that of the old hub and all your devices will connect as before.
Message 3 of 5
Hi, thanks for your prompt reply.
Message 4 of 5
Strange that you're happy to except the prehistoric SH2 when the vastly superior wifi 6 SH3 is doing the rounds
Message 5 of 5
That's a different conversation - even now depending on the package you pay for, you get what you are given - should you choose to accept!
Whole house, garden, garage and half the street covered by a Flint 4 - WiFi 7 router
